1 - 14 of 14 Posts
84 230CE & 84 300DT
Does the turbo make any sound when it kicks in? I can't seem to hear it but it does feel like it works. I can feel something that feels like a surge in power under hard acceleration, but no distinctive turbo whine can be heard.
1994 SL320, '76 240D
My car does make a distinctive whine - however the trap oxidizer may cut the sound out.
84 230CE & 84 300DT
I wonder if there is some way to test it. This is my first Mercedes diesel....
Well you should a big increase in power right about 2350-2500rpm. If you have driven anoth...
Well you should a big increase in power right about 2350-2500rpm. If you have driven another turbo car you know - turbo lag. Other than that I guess you could install a boost gauge in the car - that would be pretty trick - especially if you could find a spot to hide it so it looks almost stock. Maybe where the clock is - under the tach. Hmmm........
84 230CE & 84 300DT
Sounds like a good place but it would be a challenge. The first thing would be to get th...
Sounds like a good place but it would be a challenge. The first thing would be to get the cluster out...sounds easy but I haven't been successful yet. I haven't ever looked for boost gauges since I've never owned a turbo before. Are they easy to come by? Also where on the turbo would I have to connect it to?
Yes boost gauges are realitvely easy to come by. That would be a tough install. You could ...
Yes boost gauges are realitvely easy to come by. That would be a tough install. You could just make a hole somewhere in the dash, but like I said before, a more low key spot would look beter. Autometer is one of the most popular gauge companies, but personaly I think thier gauges are boring and a little crude. I personaly like VDO. You can find a nice VDO "stock" looking boost gauge - performance products would be a good place to look - you would want to look through the Performance catalog for porsche since no MB to date has come with a boost gauge. Some other companies that make boost gauges if you want to look them up: HKS, Blitz, Apex'I, and Jackson Racing.
As far as hooking it up, I think most cars are different in they're location to connect a boost gauge. I'm sure someone who knows these cars well could tell you where to tap in to get a reading.
P.S. - when looking for boost gauges, I came across this website. Absolutely the coolest boost gauge I have seen yet! Very stealth and classy!
http://www.stratmosphere.com/oct_s4_boostgauge1.htm
84 230CE & 84 300DT
Thanks! I'll check it out!
I'll see what the shop manual suggests for a connection point....
I'll see what the shop manual suggests for a connection point. I know that there's a section about how to test the turbo.
84 230CE & 84 300DT
Now if I could only just get the tachometer to work.......
Check this out - I whipped this up real quick.Here is a quick little renedering of ano...
Here is a quick little renedering of another spot where you could put the boost gauge. I am pretty sure that there is a space in between the two sets of buttons where I placed the VDO boost gauge - I have to check that out. I think it looks good there!
Extreme motorsports sells the VDO boost gauge for $45 - not bad! Here's the link:
http://www.extrememotorsports.com/g2cat/bstgauge.htm
84 230CE & 84 300DT
Discussion Starter #12
AWESOME! Looks like it's right at home there.
Good Job!
Good Job!
Thanks! Keep us updated if you decide to do a boost gauge!
84 230CE & 84 300DT
Discussion Starter #14
Absolutely. It won't be right away though.
1 - 14 of 14 Posts
