1995 Mercedes E320 (W124, M104)
Hi All,
Planning to do a tune up, and was not sure what parts do i need, since it looks like my car does not have a rotor and distributor cap. I have changes spark plugs around 10K miles ago, so will check these as well.
I figured I need these :
1. Part Number Image --One set
2. Part Number Image -- 3 of these
I looked at coils, but they are expensive, not sure if I need to change them as well.
Is that it ? or something I' am missing ?
Thanks for input.
Vlad,
1995 E320 1974 280C
Vlad -
If the Engine wiring harness is original and the car is not having drivability problems and if you just changed the plugs 10K, I would not even touch the plugs or coils.
Not sure of the miles on your car, but I would focus on "tuning up" other parts of the car.
Engine Oil/Filter change
Trans Fluid.Filter change
Power steering fluid/Filter change
Serpentine Belt check/change
Brake Fluid change/Flush
All can easily be done in your garage/Driveway
Hi,
Thanks for reply,
Wiring Harness has been changed by previous owner
All of the items you listed ( except brake fluid change ) has been done within last 20K miles. Now it has 190K
Now, as winter is approaching, I started having strange starts: it will start up and the RMP will go up and down couple of times once in a while. I think it should be Up and then gradually down while the car heats up.
I thought that old ignition might be the cause ?
Doesn't sound like ignition. Do a search, build the code reader and read the codes on the 16 pin connector near the battery.
Hi,
It reads O2 sensor and upshift delay in transmission, but these were there for a while now.
