1 - 20 of 21 Posts
1989 190e 2.6
i checked the f.a.q. for the wiring diagram on the euro headlights but all it had was numbers. can anyone give me a picture or a color combination? Thanks, Ill post pics after i get them installed. I also bought the silverstars to go with them
1985 w201 Euro 2.3-16vlv / 1992 w201 2.6 Sportline Manual
Put pin 2 (brown wire) into socket 2
Put pin 1 (green wire) into socket 6
Put pin 3 (yellow wire) into socket 5
Put pin 4 (white wire) into socket 4
W-1-2-3 Go!
Been searching for a while but could not find instructions on which socket to tap for the city light function? Or perhaps a diagram?
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
89 190E 2.6 x2, 99 SL500 Sport
Jippi & 355190E26:
Thanks for your info! I just found them on Ebay and good thing I did not buy them yet. I'm also looking to convert my 86 to euro headlight. Do you have a link for the euro plug?
Thanks!
Phil
1993 190E 2.3 Limited #566/700
Jippi & 355190E26:
Thanks!
Phil
The euro plug socket is basically the same as the ones from your rear tail light. Either order them from the stealership or go to your local junkyard.
Here's a link to what the Euro plug looks like btw. http://katmac.com/
Don't buy from them though, way too expensive.
92 300CE/1996 mustang cobra (supercharged)/12 Civic/15 F150/04 F150 mud truck
see attached.
print and use
1992 190E 2.6
Here's how I did the wiring. I used the same wiring diagram like in the PDF in the post above. Hope these pictures help.
You'll have to rewire the black connector according to the Euro diagram in the PDF. It requires a small amount of soldering.
W-1-2-3 Go!
I was able to get the lights to work properly :)
The city light was the black for the driver side, and gray for the passenger side. Cut part of the 2nd wrap (for lack of a better term) and pulled out the wires into the respective number (city light goes into slot #3 on the 6-pin sockets). Nothing goes to slot #1.
The Euro lights I got were Hella and had the MB logo on them, they were like new and so, I was happy.
1992 190E 2.6
Good to hear you got them working properly. I got a good deal on a pair of Bosch Euros I found on ebay last year. Those city lights look so damn good on the smoked silver 190s :D
I'm going for clear corners next. But I'm not buying that depot shit. A few months back I picked up a HELLA clear corner on ebay, but only the left side. Might take me a long long time, but I'll find the right side one day.
IR MODERATOR
now pinned in faq section.
Mercedes Benz 190E 2.3-16 1987 (W201)
Does city light blinks?
Ei guys, I replaced my US headlights for the Euro headlights a few months ago. I've never wired the city lights (out of time), but now I was looking at this thread I was wondering... when you "bridge" the city lights with the parking lights, Does the city lights blink as the turn signals/parking lights???
Does anyone have the headlight switch (European) in which you are able to adjust the European headlights with Vacuum source?? :confused:
85 190e/8v & 89 420 SEL
No, it doesn't blink. They just come on with the running light. Sure, you could make them blink but that would be wrong.
I hooked mine to my key last night so that they come on whenever the car is running. (For safety)
If you need any help wiring them, send me a PM. I'd be happy to help with any questions you might have.
A 'guide' to hooking the city lights up: http://190rev.net/forums/showthread.php?t=37397&page=19#post449298
Can't reach you!
Hi,
Ok then, I will need a step by step help from you.. I tried to reach you by PM but I can't send you a message. If you can please hit me up.
I have the original headlight connectors on it so I don't know what cables do I need to bridge!.
Please let me know.
Thank you so much!
Hi,
Please let me know.
Thank you so much!
Some various links that should help you:
mti's euro faq: Euro Headlight Faq - 190 Revolution
2phast' diy euro headlight page: Euro Headlights & HID's
wiring diagram: http://www.champagnedream.org/doc/euro_diagram.jpg
1 - 20 of 21 Posts
