1997 CL500
I have a 1997 CL500, and I have noticed that when i close the trunk, the handle goes in as it should, but the latch does not pull the rest of the trunk, and there is a gap. What could be the issue ?
1999 S500; W140.051; 2003 E320; W211.065; 1973 220; W115.010
PSE pump needs to be reset. Pull & reinstall fuse located in trunk. I think it is fuse #9.
There may be a leak that caused/allowed the pump to run too long and it stopped working for the trunk close assist.
Power cycling the PSE pump with the fuse method should reset it and it will work until the next time is stops.
1997 CL500
If there is a leak, how can I find out from where it is coming and to fix this leak ? Is there a common weak spot ?
· Moderator
It is the close-assist pump that does all the "Sucking" of doors and trunk. The pump is located on the American Drivers-side near the trunk hinge. You need to take the trunk paneling off to get to it-it is in rubbery foam box, but first reset the fuse there in the trunk, and I do not know the fuse number. Try that first! If it works, your pump needs to be adjusted internally. If the fuse-reset does NOT work, then your line to the trunk(a red burgundy plastic vacuum line-inside the trunk hinge arms has to be tested with a vacuum tester from the close assist pump. It is the center vacuum line, or the third line from the end on the pump. The pump is blue on Coupe's, but I have seen the black sedan pumps with two caps on coupe's too. It is possible the diaphram has a leak if you cannot get the trunk striker to suck-in.
Here is some Star Literature 1 and 2
Hope you understand it and make it work,
Martin
1997 CL500
Discussion Starter · #5 ·
Martin
Thank you very much
