2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Hello;
I went out to my car and tried to open the trunk with a key and found the lock frozen.
Here is how I diyed it.
Remove the two large screws,
Unhook the vacuum line and power wire,
snap off dust cover and pry tab to release lock/latch,
snap off clip and remove arms,
snap out large ring,
pry out clip and cylinder slides out,
disassemble and clean everything,
ALSO, lube this lock as part of service !!!
B
1999 Mercedez Benz E320 4-Matic Sedan
locks
Beware taking locks apart is easy - putting them back together is not. This turned into quite an epic for me...
2000 E320 4MATIC
this happens to me every morning when I was in Alberta, Saskatchewan or Manitoba... I thought the edge of the trunk is frozen, so every time after I driven the car for a while, the trunk could be open again.
