'87 560 SEC, Pearl Grey/blue; 300,000+ mi; '07 CLS 550, Barolo/stone; 90,000+ mi
I'm looking at the Euro downpipe bracket hardware, and the photo in the Trucktec brand looks like the OEM version (it's about three times less costly, however). Even though its a couple of copper nuts, washers, grommets, and the presumably stainless bracket, would it make sense that the OEM is made by someone else and it's best not to chance it?
Moderator
1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
On my 500SEC, I used the Trucktec kits to secure the downpipes to the steady brackets from the transmission.
M
1985 500sel and 500sec 2012 E63 1989 Porsche 911
same stuff, i had both before i returned the MB ones that were more expensive
Thanks guys, it's interesting it has a 201 parts number--maybe that chassis had double downpipes the same diameter as well. Would one of these sets already be installed on the current U.S. double pipe/passenger side setup? Or, maybe after 32 years it would make sense to get a new set for that side anyway in case the fasteners and grommets are corroded/deteriorated (or may get damaged in the removal process).
Can either of you confirm that the correct transmission/downpipe bracket number to go along with it is 126-492-02-41? There are different versions on the Slovak and Russian parts diagrams, and have three different parts numbers. If it is the correct one, then I imagine our original U.S. system has one to facilitate the double pipe/passenger side setup, so only one more identical (but installed facing the other way just in front or behind the existing one) is needed.
