Hi.
As I haven't found any W220 update I'll post my own findings here. Maybe it'll help someone…
I do write this according to what I have learned about my own 2001 W220 S400CDI, so please correct anything that might be wrong. Also, I do not know if there are differences with other W220 models?...
My goal was to find out where a battery drain problem came from, as I couldn't find it via the fuse boxes. This is when I learned about troubleshooting the CAN bus system for not going to sleep when parking the car.
It is quite easy to do, and does not require more than a voltmeter to test!
But first of all! Troubleshooting battery drain by pulling fuses, is NOT the best way in a modern car with all this electronical equipment and wake-up hassle, and I wish I had learned this a bit earlier!...
- First you have to get your car to sleep. You probably will need access to the trunk, under the hood, both front doors, and rear right door. So you need to open them all up, then close all door/hood/trunk latches with a screwdriver or something. Then use some strong tape or a needle to keep the door-lights of. (I don't know if that is mandatory?). Turn off the alarm. Then finally lock the car with your wireless key and put it away.
- Now you'll have to wait about 30-60 min. for the car to get to sleep.
- As an ordinary multimeter usually is fused by 10A. (Ampere) it IS easier to use a clamp meter, but if you do not have this, just disconnect your ground wire from the battery, set your multimeter to the 10A slot setting, and connect between battery negative pole ( – ) and the ground cable. If the car uses more then 0,06A. (60mA.) when asleep, you should look for a drain!
- Take your other multimeter with really nice and sharp thin probes and set it to millivolt (mV). Now go and measure all your fuses by putting one probe to each side of the fuse. If the circuit does NOT use any power, the multimeter will go to 0 in a second or five. If the multimeter shows any voltage what so ever, there is a power draw on that circuit!
- Note what fuses shows activity, and when done you can go back and pull those fuses, wait for car sleep, and go look at your battery amp-meter if you have found the problem(s).
You can find tables of how much e.g. 0,2V. on a 10A. fuse implies as draw on your battery. Search for something like "Fuse voltage drop chart".
Here is also a YouTube video explaining the procedure:
If you, like me, did NOT find the draw, you might want to keep troubleshooting the CAN bus system.
First a few words to get an understanding of what CAN bus is…
CAN bus (Controller Area Network) was developed by Bosch in the 80's as a way to save on copper, and has been used in Mercedes production vehicles since 1991. Today the use is comprehensive in most all electronic equipment in a wide spectre, and is mandatory in the car industry!
It saves on connectors, pins, sensors, weight and of course cost, and is additionally fast and quite immune to interference.
The CAN bus system is basically a digital network connecting devices and microcontrollers, multiplexing data without the need of a host computer.
By this ALL Electronic Control Units (ECU/ECM) in the car is connected, and might as a result give us some headache when trying to localize a problem…
CAN bus networks is transmitting data according to priority, and CAN C (engine/chassis) has 1'st priority and highest speed. (125kbps/500kbps) This is used for all safety components and the actual engine running.
The Electronic Ignition Switch (EIS/EZS) works as a gateway between networks, and will if necessary, (like if there is a shortcut) use "the other network" to get the job done.
When it comes to finding problems with battery drain, this is often connected to the "Wake Up" system of the car, where components are not actually going to sleep because some device is malfunctioning and keep sending wake-up calls in the network. This again could produce all kinds of problems that may or may not even be related!...
CAN B (interior/body) transmit with 83kbps, and is the one where these problems usually are, and therefore the only one we are talking about here.
This is quite easy to get to, and does not require more then a voltmeter to test.
On the W220 you would be looking for one green and one white cable going together. (CAN High and CAN Low)
With an oscilloscope their signals would look something like this:
So now to troubleshooting it.
With a multimeter showing Voltage, even if it is slow, you should be able to see if you have constant voltage or if it is jumping between those APROXIMATE numbers. (I found rather 12V./0,2V at my car)
In the W220 CAN High is the green cable. CAN Low is the white one.
First, be aware thee is NO CAN bus cables at my OBD2 pin 6 and 14 as I have seen described for other models!
Also, there is no CAN troubleshooting in the Xentry DAS as I have found… That might be different with newer cars then mine 2001 model?
I haven’t checked, but you should be able to use an ohm-meter to check that you have a complete CAN bus. It should have one 120 ohm resistor parallel in each end, so the ohm meter should then show 60 ohms.
The CAN bus B network system is connected like this:
Here is an explanation of device codes:
Units connected to X30/6
N73 – Electronic Ignition Switch (EIS / EZS)
N80 – Steering Column Module (SCM)
N22 – Automatic Air Conditioning (AC / AAC)
A1 – Instrument Cluster (IC)
N72/1 – Upper Control Panel (UCP)
N10/7 – Right front Signal Acquisition Module (SAM)
N10/6 – Left front Signal Acquisition Module (SAM)
Units connected to X30/5
A37 – Pneumatic System Equipment (PSE)
A40/3 – COMAND
N22/4 – Rear Automatic Air Conditioning (AC / AAC)
N32/1 – Left front Electric Seat Adjustment (ESA)
N69/1 – Front left Door Control Module (DCM)
N69/3 – Rear left Door Control Module (DCM)
Units connected to X30/4
N10/8 – Rear Signal Acquisition Module (SAM)
N70 – Overhead Control Panel (OCP) -via N10/8
N69/2 – Front right Door Control Module (DCM)
N69/4 – Rear right Door Control Module (DCM)
N62 – Parktronics
N32/2 – Right front Electric Seat Adjustment (ESA)
N25/6 – Rear seats Electric Seat Adjustment (ESA)
N88 – Tire Pressure Monitor (TPM)
N69/5 – Keyless Go control module (KG)
Those X-connectors are some black plastic connections that you will find as follows.
All of them with plugs with green and white cables in now particular order. You have to "clip open" the connector to be able to unplug device plugs. It can be a bit tricky, but does not require force. (you might gently pry with a flat screwdriver) The "lid" goes sideways and has one "clip-lock" at each end. Underneath it reveals two metal-strips that corresponds with all green and white wires, so it is easy to see with just one measure if there are any devices keeping up activity in that particular connector.
First one X30/6 you'll find above the left side of the brake pedal. There is no need to take of anything but stick your hand in the back of the rubber cover above the pedals. If this is ok you move forward to X30/5 -then to X30/4.
Next X30/5 under front left sill.
X30/4 under front right sill
I do not know if I have done a correct troubleshooting yet, (waiting for parts) so I probably shouldn't talk with to big of words… But as I already had unveiled some devices, I jumped from measuring X30/6 directly to check some devices connected to the other X-connectors, as it was easier to access then opening up the sills…
For me it looks like the rear SAM was the culprit. I have also read it is not uncommon to find e.g. COMAND, seats, OCP, door modules, to be the problem…
Anyway. I hope this could be of use to someone!
I'll add a couple of nice .pdf's I have found about CAN systems, which also contains some other models, and from which I have picked some pictures:
MB CAN
Mercedes CAN diagnostics
Also, here is a nice site with most devices listed together with pics:
Components
And finally, I would also like to add a sentence I have picked up about battery-drain, where the EIS itself was the culprit. (this is where my DTC's pointed, so I still hope this is not the case…) Maybe it could be of use.
The other problem of 2155450808 and 2155450908 is electric leakage symptom. Maybe you will find it is difficult to start the car after parking your car whole day. It is caused by CPU instability, the gateway running all the time can’t switch to asleep mode, and EIS gateway cannot be off when EIS have been turned off. All CPU are running, so it will lead to electric leakage symptom. Many workshops don’t understand the reason, the just add switch near the battery, and it is inconvenient for owner to operate. The solution recommended is to replace 1L85D and 3L40K chip.
All the best!
/Orre
