1 - 9 of 9 Posts
Hi,
My transmission warning light has come on several times this week :confused:, both times it has been below freezing (-1 to -3):(. not sure if this has anything to do with it..!
The light comes on and stays on until i turn the ignition off and re-start:crybaby2:, according to the owners manual it will stay in 4th if this happens...!:eek:
Mine seems to be fine, can count all 4 gear changes up and down. All seems normal except the light :surrender:
Any suggestions......?..........:bowdown:
Regards
Kev
You'll need to take it to MB or a specialist with Star Diagnostics to find out why it came on. It will only keep the error codes for 60 start/stop cycles.
Warning light
The lights only come on after a few mins of use at first start up, no matter how many times i start stop that day it dosnt come on any more.So after 60 start stop cycles will the fault code store lose the info it had and stop warning me with the light every day...? :confused:
If anybody knows an independant Merc specialist in the Bournemouth area it would be a great help..........:)
Hi. Ive got problem with transmission light as well. I think its a oil level( long story) anyway. could any1 help me and tell me where in london i can find some decent place to sort it out. not mb service their 2 freakin' expensive :)
thanks
If it's doing that I think it must be detecting a fault every day and the light will not stop coming on after 60 start/stops.
thanks
Try a transmission specialist. People on here have recommended Sussex Autos. I've not been there but the advice that I have received over the phone has been top notch.
thanks
What's the long story? Always helpful to lay the cards on the table!
long story short... guy which I bought vito off, once took off the radiator and after few mins he's trying to start the engine. whe thing is... this is vito 113 with f*****g automatic gearbox. water radiator is with oil radiator as one piece. so when he was trying to start engine , oil from gearbox was just pumped out or something ike that. funny thing is the guy is a mechanic. anyway. i managed to put some oil back but the light blinks twice or more a day.
1 - 9 of 9 Posts
