2004 Mercedes S430
I have a 2004 Mercedes s430 (not AMG). I have 160,000 miles on it.
Recently, it has developed a shuddering vibration coming from the transmission (I believe). It shakes the dashboard.
This vibration occurs typically around 1700 RPM when going from 2-3 gear, but can happen also around 40mph and is somewhat random. Going slightly uphill makes it worse.
Driving in manual mode seems to make the problem "less worse" but it still occurs; however, usually in 6th gear.
Anyone have any ideas?
2004 Mercedes S430
I had the trans mount replaced about 4 weeks after it started and it's still doing it, but I've heard about the flex disc issue before.
Could it be the flex disc alone? I've also heard about contamination in the trans fluid.
I appreciate the answers. This forum is really great.
