Would anyone very familiar with the W126 transmission be able to say if there is an aluminium washer stuck on the torque converter by looking at these pics? I don't have good enough access underneath so took these pics instead.
2624922
2624923
2624924
Outstanding Contributor
1989 560SEC, 1989 560SEL, 1995 E420
I would say no. If that was a sealing ring we're looking at and you removed it, you'd have a deep recess in the TC and I don't think that's the case. Sorry I can't be more sure.
Moderator
1991 500SEC 50K mi. 1987 560SEC Now 153K mi. 2020
There should be a soft-metal seal washer at that location.
If you have a screw starter tool with a small magnet at its tip.. You could tell (I think) if there is one still there, comparing the pull from that surface & the converter body.
That said, it looks as though that surface is machined steel from way over here.
M.
Thanks guys, there was no sign of a sealing ring in the drained fluid and nothing on the plug.. If anyone knows if there should be a recess there then that would answer the question. I wanted to put it back together today so i reinstalled the plug with a new ring so hopefully it will be ok..
350SDL, '17 GLS450, "Grandpa's Roadster" Project Car
Well, now it's pretty badly scratched up. I hope it seals properly. Next time use a pick and try to hook the back side.
That’s exactly what I tried to do hence the scratches, I’m arm outstretched with a pick and a camera, not ideal I know
