1 - 8 of 8 Posts
'99 CLK320
Sometimes my '99 CLK 320 shifts very hard in low gear. Usually when accelerating and then pulling off the accellerator in first gear.
Has anyone else experienced this? Is this a problem that needs to be fixed?
CLK430
Thud
Mine does it as well..but only when down shifting from 2nd gear into first, unless im at a stop or close to it, they its a smooth shift...so i guess this is more common then i thought
1998 CLK320
same problem
i have teh same problem. my transmission on my 98 320 is rough from first to second when accelerating. I am almost ready to replace the tranny or maybe it is a lack of fluids of new mounts that ineed?
1999 CLK-320
same problem
i have a 99 CLK320, and when accelerating at about 15-20, the tranny drops to 1st, i believe, and does the exact same thing..im glad i read its happening to other MB's because i was getting a little nervous
2003 CLK430
Rough shift
I have a 2003 Clk 430 and I get the same thing. The MB trans is the roughest shifting trans I have ever driven.
Hi
Mine does the same thing smetime is does this thump when slowing down and as i qucikly accelerate it does the thump also. I will have it check monday will see.
1 - 8 of 8 Posts
