Guys:
I got the transmission on my E320 (2001 model with 74K miles) repaired by a Merc Authorized reputed service place about 2 months ago as I had noticed some very minor slippage in the first couple of minutes after starting the car and never later (only about twice in 2 months). While I am now totally convinced that the repairs were absolutely unnecessary & there was nothing wrong with the trans. at all, but it's all in the past now.
Anyways they opened the transmission, replaced the "one way roller clutch" and a few other minor parts. After the repair I have noticed the following issues:
a) Transmission not engaging when shifting from reverse to forward and when it engages it does with a loud thud & a jerk.
b) The car “stalls or “just does not respond for a few seconds” when I press on the gas pedal suddenly to increase speed as in merging (NOT all the way down, but exert some extra pressure) or even during start.
While both the above issues have happened in perfectly normal conditions more frequently in the weeks after the repair, over the last 2-3 weeks I have noticed they occur only under wet & slippery conditions. But, as I use the car very little I cannot say with surety that it does not happen under normal conditions. I have always ensured that the ESP was on.
I took the car in to try to demonstrate the problem to their mechanics on a wet day, but couldn't simulate the problem. They checked the error codes and did not find any. They believe that it may be due to slippage at the tires. But my tires are good and properly inflated.
Can you tell me what might be going on and if indeed that was a trans. issue as I very strongly suspect?
I greatly appreciate any help in this regard.
