1 - 10 of 10 Posts
84' 500 Sl , 2013 W221 S 350 Petrol
hey, ive been away for sometime trying to solve the shifting problem in my transmission...
the problem is, when i drive normally, upshifts and downshifts are perfect. but when i accelerate fully ( pressing the kickdown switch ). the first upshift ( 1st to 2nd ) is perfect, the second upshift doesnt happen ( 2nd to 3rd).
if im driving at 80 Km/hr and i press the pedal fully with the kickdown, then downshift happens, but the upshift (3rd to 4th ) never happens.
so what im having is no upshits from 2nd to 3rd, nor from 3rd to 4th, while the kickdown switch is pressed.
i had this thing since i bought the car, i did overhaul to the engine and tranny.
still the problem is there.
fuel system is all new, kickdown switch is new. valve body is repaired. im tottaly confused.
tranny oil level is good, new governer, clutches filter installed.
any help? plz? any one with a similar problem??
thanks
It Is What It Is, Dude
I don't know the procedure offhand, but there are specific throttle and kickdown linkage adjustments that are critical. Also the vacuum modulator, and the line pressure adjustment for the modulator are possibilities.
Welcome back.
Current: S280 (97), E200 Kompressor (01). Previous: S500 (92), S280 (95), 300E (87)
Transmission problem shifting up at full throttle
thanks
Hi, did you ever get this issue resolved? I have a similar issue with my S500 1992. I will send money $$$ via paypal for info that solves this problem, thanks.
actually what solved my problem, was getting a new valve body!
i found one laying in a store for sometime.
after installation upshifts and downshifts are perfect.
turned out that the guy who repaired my valve body didnt have new sping set, so he used springs from other valve bodies!!!
if i knew how to fix it myself, my tranny wouldnt be a testing rat for more than 12 times repair :mad:
got few final adjusments though to finish.
Well someone asked in another thread why do I DIM. Here you go.
I cant complain too much I actually did this on the first automatic trans I rebuilt for a 1960 T bird, I was about 15 years old.
1978 280slc
I know my tranny is kind of jerky, but it still runs strong so I don't worry about it. Too bad they didn't use a better final gear in the 4 speed auto. I like that it is high revving but not when you are running 4500rpm at 85mph, with long legs.
I heard of someone using a taxi tranny in an xk150/120 which sounds like it'd really keep the revs low for better mileage. I think the car has enough grunt to run a different transmission, but it works good now.
I have 2004 CLK 320 and my car sat for 5 months without being driven in cold weather. When I started to drive my car about 2 weeks ago, the transmission seems to be messed up like it's started in high gear. when I turn off the car and then turn back on, it drives the way it should but then it will act up again in a little while, and now the check engine light came on because it wouldn't go into gear. Does anybody have any advise on what I should do.
Welcome to BenzWorld. This is the R/C107 board, for the SL model. I'd suggest you post your query over at the W209 board where you'll find people with more knowledge and experience with cars like yours. Ours are dinosaurs compared to what you have. Good luck!
W209 New CLK Class - Benzworld.org - Mercedes Benz Discussion Forum
1 - 10 of 10 Posts
