1985 380sl - charcoal grey w/lt grey interior
all,
my 2000 E320 shifter will not move out of park so i used a pen and released it manually as described in owners manual.
transmission works fine just will not release out of park....car runs and drives perfect and shifts perfectly.
**anyone have any idea what the part is that needs to be replaced??...i assume it is located somewhere under the brake pedal??
happy turkey day to everyone!
william
1999 E320 w/118K
I had the same problem with my car about a year ago. Problem was a broken piece of plastic inside the shifter module that slides back and forth when the shifter is moved. I had to replace the shifter module. Took an hour or so to do it.
Commonly it can be the brake switch, or caffeine/sugar drink contamination of the shifter - those are the (2) most common problems.
2001 E270 CDI
most probably the brake light switch. It is located above the brake pedal. Try using contact cleaner on it and hopefully wouldn't need a new switch.
2013 E350/41k, 1997 E320/290k, 1999 FJ100/256k
.. and if a new one is needed, they are about $18 at autohausaz - maybe under $30 at the dealer...
solenoid
when you go looking at the 'spill' problem with the shifter also look at the solenoid. if you haven't had a ball of problems with the ECU/TCU (under the hood) there would be no need to do an adaptive reset. Always find it a good idea to put pep back in the shifting.
happy holidays,
d.
