Does anyone know if the solenoids are all the same part number or is each one different? ie: (1-2shift sol, 2-3shift sol etc) they seem cheap enough online and would want to replace all while i'm in there.
Background, transmission was doing the funky limp mode would be stuck in either 1st or 2nd gear, it got worst to the point that it was stuck forever let it sit for weeks reset, numerous times and still no shift out of 1st/2nd changed plug AND conductor plate and nada, changed TCM bingo everything back to normal but every now and then after a long drive stop to get gas or stop at a store get back in, it's stuck in 1st/2nd, turn back on a few times resets and back to normal.
I plug in a scanner and it reads 2-3 shift solenoid, so are all 6 of those solenoids on the conductor plate the same?
part# anyone?
the dealer said they usually sell the conductor plate with the solenoids, so they don't have part numbers for the solenoids themselves, is this true?
The tranny oil is clean no debri, not black, truck has 177k 1999ML320
02 ML320 06 ML500
Here's the illustration which explains which is which. Also remember that you must clear codes from both the ECM and the ETC/TCM (two separate functions) after each repair. You must use a professional grade/dedicated scanner to do so.
