hi
i got oil leak from the connector in the transmission or the mechanic change the connector and the oil and since than when the ML 320 1998 159KMiles
when i drive it for 30 miles stop for 5 min and restrat the transmission stuck in first gear
he change the electronic plate inside the transmission but still have the same problem
when the ML get cold the transmission the next day work like normal
is it a bad kind of oil he put?
he put Eurol ATF synthetic oil
please help
best regards
02 ML320 06 ML500
You have to clear any and all codes from the Engine Control Module.
Then you have to clear any and all codes from the Trans. Control Module.
the problem was the gear motor causin transmission to stuck on first gear i change it clear all codes and it works fine now
