Background
The vehicle is a 99 E430, bought November 07 with 39,100 miles on the odometer. The car has been serviced by the local MB dealer prior to my purchase. Originally MB touted the transmission oil to be for the life of the car; however, in latter years MB had a reversal in their philosophy and recommended changing the oil around 80K miles. This certainly worried the owners, as many had already exceeded that mileage. In the interest of establishing a baseline, I have decided to use my car as a data point so:
On March 09, the transmission was serviced with the recommended 722.6x MB oil, along with an OEM filter and gasket, mileage was 53,457. Being a 99 model the converter oil was also drained and replaced.
Disposition
A small quantity of brownish transmission oil was collected and submitted to Blackstone for lab analysis. The oil didn’t contain any visible particulates or have a foul odor.
A copy of the lab report is enclosed for your review.
http://www.benzworld.org/forums/attachment.php?attachmentid=230260&stc=1&d=1238514893
Note that aluminum, lead and tin are high. As the lab analysis indicates, I would not be too concerned about the numbers because:
• First oil/filter change
• The aluminum level is likely the product of the aluminum components during their initial wear in process.
• The tin likewise comes from the load bearing components via the same process above.
Conclusion
• Based on my rotating machinery experience and the lab analysis there is little concern at this time.
• I will service the transmission again at 100K miles and compare the before and after results.
In the meantime I would suggest that those with 80K miles or beyond with the original transmission fluid to consider having the fluid and filter changed so as to insure the longevity of the unit. If you have $22.50 burning a hole in your pocket have Blackstone check the oil as well. It would be nice to have some oil with ~ 80K miles and some with ~ 125K miles as data points to evaluate the oil longevity and determine the most cost effective change schedule.
Any takers??
Disposition
Conclusion
Any takers??
