mercedes 300sel
i will be changing the motor mounts and transmission mounts. ive got the idea of how to change the motor mounts, but usign ght e jack under the oil pan to lift it sligtly, but do you do this, to remove the trasmission mount asweel? anyone have any ideas on how to change this.
and i held the 300sd engine and shaked it back and forth the other day and heard some swooshign noise. i beleive the motor shocks are done, shoudl i purchase the mountign kit or can u just change the shock, and whast the process to do this? thanks for the help
Depends on the day!
once you drop the cross memember for the trans it will become rather evident w/ the trans mount.
Purchase the shocks and the mounting kit, doing just shocks is a half a$$ way of doing it. Do the shocks while you have the engine up for the mounts.
Jonathan
It was recommended I have new engine / or transmission mounts ? What are the signs of needing this ? What's the difference between the two ?
