2004 ML500,Sport; 2014 ML550; 2009 ACURA TSX
Question is why would you consider a used cooler line for transmission instead of new part. It's relatively inexpensive.
2003 ML 500, 1985 735i Euro
There is a '01 ml 320 that I'm trying to get parts off of. I agree that new lines are the best option, but I am trying to fix multiple things that add up to alot when dealing with new parts. New lines are on my list, but the used ones are a better band-aid than what I currently have.
02 ML320 06 ML500
No they will not fit and the reason is the 500 has a longer engine and requires longer lines. Also they have different part numbers.
Thank you, that's what I was looking for. I went to check it out yesterday for some HVAC parts and it had the manual vent set up so I didn't get to use anything. I did get a rubber pedal cover for the parking brake, WOO HOO!:rolleyes:
