Is this where you check the transmission fluid? Also the dip stick I have is long as hell so im not sure if this is right because its right on the transmission
:thumbsup::thumbsup:Its located on the right side towards the firewall.
Ok I found it, thanks, it is black and says "Mb workshop only" on the cap
Why else would you dip it.............................................?is there a level indicator on the dip stick?
Actually that indicates one of two things: either it's never been replaced or someone finagled with it from the underside to release it without breaking off the tab.I guess they changed the color to all black for 02
