2001 E430 Sport 2000 E430 1990 300CE
I have 43000 miles on my 98 E320. Mercedes claims the tranny is "lifetime sealed", and does not recommend changing filter or fluid. This sounds crazy to me. Any thoughts?
Also, what about spark plugs? Mercedes says change at 100,000 miles. I was thinking about 50,000.
The car runs perfect right now.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Do a search and you'll find lots of opinions on the ATF issue. I changed mine at 50,000 and will continue to do that. On another forum, an MB dealer tech said that a technical service bulletin just came out from Mercedes advising to change the sealed for life fluids in some transmissions at 40 to 50,000 miles. Big thing is to use only MB fluid and get the level absolutely accurate.
Len
'99 E300TD 75,000 miles
