Hello,
I have a 2011 A160 petrol with CVT which after was parked does not want to start anymore. When I turn the key there is no sound from the starter and on the instrument panel are missing the informations about the gearbox lever position. I've read the errors and there is no communication with the TCU. There were no errors before this and the car was running fine. I've checked the fuses near the battery and all are OK, but i see that there is no voltage on the fuses F26 and F27 after i turn the key. Could this be the problem? Does anyone knows if the TCU is powered from a relay on the SAM or have a wiring diagram for the CVT ?
