1 - 20 of 25 Posts
anyone know where the TCM is located....ive seen posts and videos showing in the diver foot well above the gas pedal, to the right...and behind the front passenger foot well under the dash...not in either locations ...thanx
1998 E320 base sedan @ 160kmiles
It is under the lid of the module compartment at the passenger side under the hood. The module compartment is just in front of the firewall. The TCM is the module closest to the fuse and relay module , K40.
mrboca
thanx for the response ...is it in this compartment in the pic?
2622270
1999 E320, 2000 E320, 2003 E320 Wagon, 2005 C230K SS, 2010 Accord LX w Eibach & Koni FSD's
It's the big black plastic box in the back corner on the right hand side. The lid is secured with 4 screws.
thanx 260e cruiser....behind the fuse box ..right by the hood hinge?
Yes, near the right hinge. Fuse box is on opposite side.
Are you sure you want to mess with it? You sound a little lost.
Is your transmission in "limp" mode?
throwin 2 transmission codes that are TCM related ....went through reset transmission and goes right back to TCM code ...we shall see ...thanx for your help
Are you having any symptoms?
Are you reading codes thru 38 pin socket in the fuse box?
Discussion Starter #12
the transmission wont shift ...will go in reverse ...so prob in limp mode ...pic of lid off...i dont see the TCM..the back part with the 3 yellow relays can come out...is it under there?
2622276
As far as I know, transmission codes on a W210 can only be read and erase thu the 38 pin port with a scanner capable of reading MB codes and a COMPATIBLE adapter cord.
I do recall someone posting in the past that he was able to do so thru the OBD II port with certain scanner.
the transmission wont shift ...will go in reverse ...so prob in limp mode ...pic of lid off...i dont see the TCM..the back part with the 3 yellow relays can come out...is it under there? View attachment 2622276
Wrong side. I said passenger side. People get confused where right and left is as it changes where you look at it from.
You can read the Transmission codes (more detailed than pre-facelift models) translated to MB specific P2------ codes, but you cannot reset them. You need to access the 38 pin connector for reset. (the one in the above picture, with a proper scanner).
https://www.benzworld.org/threads/where-is-the-transmission-control-module-tcm-located-on-e320.1336671/
Right hand side is from driver's seat! That's the fuse box.
Two thing you need to check first:
1) Transmission fluid level with the PROPER MB dipstick tool. Engine must be running and in park.
2) Transmission electrical connector (pilot bushing) for fluid intrusion. Lever must be flip down and plug removed.
Can your shifter go into drive?
Discussion Starter #17
i read with OBD..and got these 2 codes ...and it did clear them
A P0715 trouble code is related to the communication between a vehicle's engine and transmission. When the input speed sensor does not receive a signal that is within the manufacturer's parameters, a P0715 will illuminate as the transmission will not be able to read the engine RPMs to shift properly.
P0700 Mercedes-benz Description
When the TCM detects a malfunction with the control, a signal is send to the Engine Control Module (ECM) to trigger the Engine Light or Service Engine Soon light. The ECM stores the P0700 code and it means the TCM detected a malfunction with the transmission controls.
Discussion Starter #20
thanx help ..ordered a dipstick...and understand the connector issue that you mentioned....appreciate the input..will let you know how goes
1 - 20 of 25 Posts
