1 - 1 of 1 Posts
Hi all. I was under the impression that all the trans were similar but searching on ebay I did find an auto trans that is described to be compatable with 4matic only. Then I found another that states:
THIS ITEM FITS:
MERCEDES 300E 1990-1992 AUTOMATIC TRANSMISSION 124 Chassis Type, 3.0L, base (RWD)
300TE 1990-1992 AUTOMATIC TRANSMISSION 124 Chassis Type, base (RWD)
Obviously the transfer case is an issue but can the above transmission fit my 1992 300E 4MATIC car and motor or not??? Is there a trans only special to 4matic?
Thank you,
Brad
1 - 1 of 1 Posts
