2004 S500 4 Matic and 2005 C240 base
So I was at the dealership picking up parts and mentioned that the Transmission shifter is loose. They sold me a $4 green bushing. I have seen video of folks on lifts replacing the bushing….my question, can this be done fairly simply from on top thru the console? if so does anyone have a link to DIY for this…
thanks
another question on cluster is if I purchase a brand new cluster then can I plug and pay or is it a reprogram needed.?
Thanks in advance
Grey Tints and shades Wood Circle Road surface
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
I believe that bushing goes on the shift rod where the shifter attaches. It's installed from underneath.
A new cluster must be programmed using SDS.
Yes you can replace this bushing from the top, but that would require the removal of the center console and shifter assembly. Sometimes a much cleaner way to do this, but obviously much more time and know how.
Yeah the cluster would need some programming for mileage and service settings at the dealer.
