1 - 12 of 12 Posts
'75 240D
Looking for the right side hard transmission line from trans to radiator, and hopefully the rubber bushed support clamp as well.
Is it available from dealer, other vendors, should I get it used or have one made?
Just replaced water pump, removed AC, installed new vacuum pump diaphram only to reveal the mystery transmission fluid leak I couldn't find previously. Now with all this good vacuum the next weak link reared it's ugly head. Looks like some boob clamped the bracket without a rubber bush in it and sliced the line, so much for service shops.
David
Administratoris Emeritus
2021 SL770
Metal line will be difficult to find, probably best to have one made up. Rubber hoses OTOH, are readily available.
2021 SL770
'On the other hand'
1965 220S, 1999 Volvo V70 (wagon), 2006 Ford Crown Vic Police Interceptor, 72 350SL 4 Speed
Take your chassis number to the dealer and have the parts person look it up. They can order it for you.
2021 SL770
Chassis number = VIN.
The VIN didn't begin until the early 80's. Until then it was a mish-mash of numbers and letters from the manufaturers, excluding Mercedes Benz of course.
Doesn't really matter which model the steel pipe comes from or which side of ther engine( they bend with small tube bender easily) . They are a generic item .there are 4-6 and V8 pipes. head for a wrecker and grab one from any pre1980 four cylinder or 5 cyl. Merc. Buy a new rubber hose from the nearest dealer. Again they are all the same basic part so don't sweat having to find a specific year part or what ever. Just use a piece of rubber on the steel line in the existing bracket.
Discussion Starter #10 (Edited)
Repaired line
Thanks everybody;
Took my existing line to a local industrial hose and filter shop, they said they could fix the piece. They cleaned up the areas and silver soldered them and it works great. Found a total of three slits and two prospective pin holes. The cuts were due to overall gunk build up between the deteriorating bushing, clamp and line and constant vibration.
Also replaced the bushed brackets on both sides, had new flex hose installed on exiting ends which have a different taper than what they had available all for under $40 and less than 1/2 hour in the shop.
Now back to my unfinished vac issue!
Regards
David
2021 SL770
For the purpose of identifying parts, the terms are synonymous and completely interchangeable.
2021 SL770
Thanks everybody;
Regards
David
Good choice, local resources can usually come up with just about any kind of hard line you need, as long as you can provide an example.
1 - 12 of 12 Posts
