i have 2002 s500 how do i check the fluid in the trans:surrender:
You have to get the special stick Mercedes part number 140 589 15 21 00 , you must check the fluid level when to car is up to full temp.
Now if you cant get that, get a used tranny stick (any maker) over 30 inches long. Mark from the bottom to the top 27", that is where you stop putting it in the hole. Now 2 3/4' up the stick make another mark. That is the full mark at full temp.
Hope it helps.
this my sound crazy but how do i take the cap off the line i pushed down on the plastic piece an it broke off:surrender:
Pull straight up. You are talking about the red lock? It broke off? It always does. But the black plug is still in the end of the long tube?
Can I say black plug and long tube in the same sentence?
