1 - 9 of 9 Posts
'00 S430
I have decided to change the trans fluid (drain/fill/drive/drain/fill).
How does one remove the "dealer service" plastic plug on the fill tube?
What does one replace it with? I have not found a source for one.
I have used the search function and came up empty.
2002 honda civic (sold), 2009 Mercedes ML350
you break the old lock on the cap and replace it with a new red lock. they are sold at the dealer for less then $2
'00 S430
Thanks, I saw that red contraption on AutohausAz and wondered where it fit. It is $0.88 and the fluid is $15/qt.
02 S430 - 00 ML55 - 91 NSX
You break the red tab and drive the rest of the locking pin thru. You can reuse the pin without the top tab.
Tranny only drain out 3 qt or so. That mean you have to change the fluid many time over to get the 8.5 qt out
There is a new MB ATF that is about $8. It is the MB ATF 3353. Its Pink.. Old ATF in your tranny had probably turned brown.
You can drain the torque converter on the car, along with the pan drain you will get about 8 of the total nine quarts out. Use the MB synthetic that is made for the car, it is expensive but worth it.
'00 S430
Discussion Starter · #6 ·
Thanks guys, the red thing I saw online looks too big to fit. I do plan to use te proper MB syn fluid, it runs $14 at Autohauz Arizona.
the newer models have no plug to drain the converter. the easiest way to get all new fluid in there is either use a tranny service machine or disconnect a line at the tranny and run the car and continue to topm off the fluid level untill fresh fluid comes out.
2002 SLK 32 AMG, 2000 S 430, 2003 ML270 CDI
Which is the last model that has the torque converter drain plug? Where is it located?
Zotye Auto 1.5T T600 2016
I cant give an exact date but the models you have (according to your) profile are beyond 2000 and therefore should not have the TC drain plug.
1 - 9 of 9 Posts
