2000 W210 E55 AMG, 2002 SLK32 AMG, 2007 W164 ML320 CDI
Hi all I have just experienced some tranny oil leaking problem...I cant see it clearly where is it leaking from before I jack the car up but from what I see it seems that it is leaking somewhere near the gap between where the tranny and engine mate together. has anyone experienced this before? I tried to search the forum and all the tranny leaking problem seems is from the electronic connector but not where mine seems to be leaking now. Thanks for all your helps!
'68 280SE (w108), '72 280SE 3.5(w108), '88 560SEL(w126), '97 E50 (W210
I had a friend whose tranny was leaking from the banjo bolt on the side of the transmission. Best to put the car on the lift to ascertain the source of the leak, as it could be possible the leak is from the electrical connector and wound its way down towards the tranny bellhousing.
I'm sorry but there seems to be no better way.
