I have a 2006 C230 got the same code P2725 Pressure control Sol E, I changed that and fluid and filter. Cleared the code. Ran great for couple days. Then in the morning back into Limp mode again.Now it says code 2725 but this time it says Internal Electrical Component Y3/8y6(B2 Brake Control Solenoid valve(VGS)) Has Failed. Code 1749 Fault present in control module transmission. So goodluck. Make sure you do everything the first time, because it will cost more everytime you put it back together and have to take it back apart a 2nd or 3rd time. A waste of money and alot of time.Did any of the issues get resolved?
Im having the same limpmode issue on my '08 W221 it has the check engine code P2725 for pressure control Sol E.
