83sd w126.120 617.921
Well, first off 83 300sd with 205k on it. Anyways almost all vacuum lines are filled with tranny fluid. As i remember last time i looked (a few years ago) it was a green soleniod on trans with a black rubber cap (cap cracked and leaking). I think it"s called a modulator valve. The vac system fills with fluid so i guess i don't have to worry about carbon/sludge build up! Can this solenoid be repaired or have to be replaced or is it an internal trans baffle? Any insite thanks! I do have a few 126's in local scrap yard to pull parts from.
oh also the vacuun levers(on valve cover) are worn out.
J
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Welcome to the forum.
Don't take this the wrong way, but by clicking 'User CP' on the top tool bar, you could complete your profile with the car mod and location, to make it easier for members to offer advice.
For how to, and other useful navigation help please make sure to read the 'Welcome' announcement / tutorial sticky on top.
Cheers
"500"sel, 560sec
Buy a new modulator, no biggie.
'01-E320 & 02-ST2
Plus one, it has a diaphragm inside that has ruptured, change the modulator and you'll cut down on the mosquito fog you're leaving in your wake. :)
Take care and enjoy the ride,
Greg
