1 - 20 of 20 Posts
280GE 320TE 280SE 3.5 ML500
I've a late '93 500 that I want to over ride traction control. Is there any way of doing so?
Cheers
SL55, 300SE, GL450, Daytona 955i
Peter Guenther said:
I heard disconnecting the two leads at the brake light switch will fool it
and set the ASR light in the dash!
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Cheers
Not a relay.. but I think you can remove the modual fom the box in the engine compartment. top rh corner. coffin shaped with 4 screws holds all the acive mods..try that first before you go messing with anything else..
1993 300SEL (Sold) 2007 X5
Woops, that was waht I was meaning.
92 500SEL to 01 E320T current 2014 lexus LS460
I saw this advice in a article wriiten by Stu Ritter one of the "technical guys" in the "STAR Mercedes publication".
There was no indication as to ASR illumination, I would not be pulling modules out of the box, you could get yourself into a limp home mode. I would never mess around in that box, unless someone says they did it.
if it is switched off I would want the light to tell me, so put a switch in series with it to enable and disable.
Yes but If it goes to limp home mode you just put the modual back in . and you are no worse off.. I know that some where made without ASR fitted. so..
Discussion Starter · #10 ·
he he he.... like mine (Photoman wipes egg off face). There is lots of rubber on the road that shows I don't actually have traction control :) ..... oooops
I dont have ASR either, I found that out on a wet day.......
cjawahir said:
:rolleyes: Hi all, first of all great forum, I would like to know, did you run the car with out the ASR module?
Charitar
He worked out that it did not have asr in the first place.
Hi NZBenz, may be you did not understand my question, I am asking did the vehicle run without the ASR module ,without going into limp home mode?
charitar.
Discussion Starter · #15 ·
I don't have traction control. Never did. I just presumed I did... till leaving lots of rubber on the road :)
At this point I discovered I never had it in the first place
Discussion Starter · #17 ·
might need it though... getting supercharged soon :)
Will have to look at getting an LSD
How is that different from what I said?
1 - 20 of 20 Posts
