1 - 20 of 44 Posts
MB ML430. Car will not start, as if there is no battery connected. Not a click, or a light anywhere, not even an idiot light. Drove fine two days ago, parked it indoors, went to start it next morning , and NOTHING. Checked fuses, none found open. Could it be the famous " FUSIBLE LINK" ?
And, I have no idea where to find it. Can anyoner here help?
Many thanks ahead.
Battery is at 12.5 volts...which is meaningless unless there is a load on it...incidentally, I am a degreed electrical engineer ....thank you for asking anyway
Is there anything alive? Interior lights, hazard flashers, door locks?
Here is diagram of starter circuit.
Witek I can not find it now but if my memory is correct you helped on this one...
"a member drove his ml to work, parked for the day went out to start it after work and no start."
Then with forum help he found not that a fuse was not blown but it was not there at all. I can not remember what his start issue was: no crank, crank, lights no lights.
Witek do you remember that one I think you got involved? I tried searching for it last night but could not find it. If something is off with the remote he would still be able to start it would just die correct?
Discussion Starter #12
B
BTW...my apologies , I was not trying to impress anyone with a degree in EE, just wanted to reduce the number of questions re electrical area, that's all. Still, I do apologise if that went the wronmg way. And the schematics are very useful, than ks again.
Carmel unless you got it figured out you may want to read this case, it sounds similar.
Discussion Starter #19
Went through all basic tests several times, decided to do something very different. Took my FOB key housing apart, BINGO...a " chip" had actually come off the internal pcb. The ignition could not read the FOB signature....anti theft at its best...really working. Thank you all on here.
1 - 20 of 44 Posts
About this Discussion
9 Participants
art_arev
Mercedes-Benz Forum
Full Forum Listing
