Zbordas,
Oh man, I hope I don't need to do that...after just putting the bearings back together. So when you did this, after removing the the torsion bar bearing plate there is now no load on the bar, and you just put it back where you marked it???
I used to race older porsche's which had short TBs running left and right. If they were ever removed it was just a guessing game to adjust them..In our class the torsion bars had to be in place, but the rules didn't say they actually had to work. So in order to mount coil overs I took mine to a machine shop that made battleship gun barrels. It took them 8 hours too grind the teeth off of one end on a lathe, then I reinstalled them...they couldn't believe it, they said they were made of magnesium. Of course they did nothing now and I could use my coil overs!!!
