Is there a torque wrench out there that works well with the W123? Typically you can get away with snugging certain bolts down but it's not a great idea since you can either under-tighten or over-tighten certain nuts/bolts such as the one's on the valve cover (which leaves you with a failed seal). That's a given.
There are many brands to choose from so I simply want to know which brand & model works best on the 616.912.
