Does anyone know the torque values for the transmission pan bolts and drain plug for a 2001 E320? I'm going to be changing the transmission fluid soon and would like to make sure I put everything back together right. I also plan on draining via the cooler line; how tight do I need to tighten that when I'm done?
The drain pan bolts have a special 'washer' to control the compression of the gasket so examine carefully when removing first one. Torque for T30 bolt is 12Nm.
Drain plug is 5mm hex at 24Nm. You'll need a new washer.
Don't know about cooler line.
Check DIY above for all details.
