1 - 8 of 8 Posts
1999 ML 430
I have a 1999 ML-430 recently asked the torque settings for the valve cover. Before covering up the heads I would like to check and tighten the 20 head bolts. I do not know the torque settings & sequence, in the past I would start from the middle in a x pattern going out to the ends. I would appreciate some experienced advice. on the proper settings and sequence.
Outstanding Contributor
2006 ML500 2002 ML320
You asked for this same information in your first post and I supplied it.
10Nm or 7.38 ft. lbs. or 88.5 inch lbs.
1999 ML 430
my mistake I should be more specific cylinder head bolts that hold the valve train: valve springs, Keepers , rocker arms, etc to the engine block. it takes a t-55 tork. 10-half of them are on the outside of the valve cover next to the spark plugs, 10 are on the inside on the cylinder head before you put the valve cover back on.
1999 ML 430
my mistake I should be more specific cylinder head bolts that hold the valve train: valve springs, Keepers , rocker arms, etc to the engine block. it takes a t-55 tork. 10-half of them are on the outside of the valve cover, 10 are on the inside of the cylinder head
Cylinder head bolts do not become loose. Checking for the proper torque is impossible, especially on an aluminum engine, because they use what is called Torque to Yield bolts. They actually stretch when tightened. If a head has to be removed, for whatever reason, new bolts must be used each and every time. Don't worry about them and do not tinker with them.
1999 ML 430
Discussion Starter · #6 ·
thank you very much for the information, I will follow your advise and leave them alone and just put back the valve cover
head bolt torque settings for an SLK 230 1998 2.3
Hi. Please could someone help? I need to know the head bolt torque settings for my SLK 230. Cheers Pete
1 - 8 of 8 Posts
