1 - 9 of 9 Posts
1988 Mercedes 500 sec
I am ready to put all my front suspension back together its a full rebuild does anyone please have the torque settings for all the front suspension components at hand
Moderator
1991 500SEC sub 50K mi. 1987 560SEC Now 150K mi. 2018
In case you still need........
Here are captures from the MBCDs.
M.
any idea what the torque setting is for the front antirollbar bushes and does the split section of the bush face the car interior
i have removed the old bushes so the roll bar is now loose can it be tightened down in any position with the new bushes or does it have to be tightened down when at a certain angle
Moderator
Looks like the slit faces REAR
There is no mention of torque spec, just use new self locking nuts...
Should be a straight-forward torque based on fastener size I should think.
Thanks rear as in towards the interior
Ie towards windscreen
Does it matter what angle the bar should be at before fully tightening down the bracket
Moderator
Hey there!
Though not mentioned in the MB literature as far as I can see, I'd try to have the car sitting at rest [supported by the springs] before securing the fasteners..
I should think that approach would serve best interests.
Cheers,
M.
Yes currently car is stripped no suspension control arm spring shocks are on car starting with sway bar and building back up
1 - 9 of 9 Posts
