I just installed an H&R cup kit, great kit I might add, but while I had it apart I thought it'd be a good idea to replace the ball joints, sway bar links, upper control arms, lower control arm bushing(huge pain in the A$$) and tie rod ends(not their yet).
The WIS says to torque the control arms with wheels on the ground, which I did, but I feel it's making the car even lower than the cut kit was designed for.
Right now I have 12.5" between the center of the hub and the wheel arch in the front on #4 pads and 18" rims.
Does this sound right?
If you have a cup kit can you chime in on what measurement you have between your hub and wheel well arch.
Samson
Samson
