If you search,
you will find old posts, some are mine.
I was able to repair a few of my top cylinders.
That was more then a decade ago, before Top Hydraulics.
I used a cone from a bicycle pump, it never leaked.
Years later, I asked Klaus for his assistance.
(Very pleasant personality, had fun talking to him.)
Most of the time the cylinders leak from the top seal, so you see the oil....
but there is more to it.
The piston seal. Pressure comes in from one side, piston extends, pressure comes from the other side, piston contracts.
I m not going in detail of how the system works.
Yes,
you have two valves that one closes the other opens, and so on.
Now,
if you buy the seal, you will be doing a half job.
Piston seals swell up, need more pressure, more pressure will damage the system.
Top Hydraulics replaces all the cylinder seals.
As far as I know, nobody ells does that.
Klaus prices, are reasonable, his service, is second to none.
Regards,
aam.
