SLK 230
Setting up a tool box just for my SLK.
Please help by posting the tool, size and what you have used it for.
If you all respond I will compile the list at the end and repost it.
Thanx.
SLK32, ML430
How big is the tool box you are setting up?
Screw driver with interchangable bits (full set of torx, phillips, and flat head)
Good quality flashlight
Ratchet set
Pliers
Electrical Tape
Fuses
Tire Pressure Gauge
SLK 230
Antique wood box
1923 Union tool co., 8 drawer. (Gerstner type)
Old world car, old world box type of theme.
Not a regular type of tool box set up, just tools for the SLK.
Examples; #12 Torx bit for the spark plug cover. (If thats what size it is).
Or 18 mm socket for the lug nuts. (If thats what size it is).
Trans nuts, door panel caps, etc.
Ill fit up some tools this weekend and post it.
* Oh BTW I didn't want a full ratchet set for example as you only need a few sizes.
1999 SLK 230- RED
Floor jack--3,000 lb capacity
80 gallon air compressor/tank
50 feet of air hose
tire air guage
air speed gun -1/2 inch.
1/2 in. extension - 4,6,8 in lengths
3/8 in air ratchet.
1/2 inch ratchet.
3/8 in ratchet.
same extensions for 3/8 in ratchet
torque wrenches - ft. pound and in. pound
screw driver with changeable tips-flat, phillips
8,10,14 mm sockets and open end wrenches.
pliers and locking vice grips
stainless steel dental picks
wheel bolt sockets
hemostat clamps ---three sizes /lengths.
wire strippers/ crimpers.
deep socket - 14 mm ? -- for spark plugs.
-------------and most importantly --------------------
---------------American Express card------------------
----------"Never start wrenching without it"----------
Regards
2002 SLK 32 AMG
The stuff I have had to buy so far include:
-2 ton low profile floor jack
-tack puller for removing the trunk panel fasteners
-17mm deep socket for lug nuts
-large (for lug nuts) and small torque wrenches
-Torx bits
