1984 380SL
And our alignment mechanic (not Jono with Blue Ridge) says one of the engine cradle bolts has broken/sheered off. He's recommending replacing all of them - as they come in a kit.
So...questions.
What are the cradle bolts called in MB terms? (it seems to be something U.S. manufacturers use)
Anyone done this job - what type of labor does it entail?
Looking at about $700 repair.
We have no clue where these parts are even located.
Thanks for your insight as always
1993 600SL, 1973 450 SL,1998 SLK 230,2018 C300, 2019 Ram 1500 Laramie, 1968 Firebird,
Man, $ 700 bucks for 4 bolts ? I want to work for you ! The replace easily from the bottom, so no idea why they think that is such a hard job ! :confused:
1984 380SL
Did a little digging and I think it is the subframe bolts/bushings. Looks like once you factor in genuine parts we're looking at about $500 in labor - to replace all of them. We did find an old thread detailing the job and unfortunately we don't have a way to easily get to the bolts - car needs a lift. We'd remove tires, tie rods, brake line and then the subframe mounts. And of course my husband doesn't have a lot of time or knowledge about this particular job for a DIY.
**and by the way, those of you who advised us early on that this beast would likely run about $2-3K per year in upkeep - you're spot on. Every season it's something new. But we do love this car.
1987 560SL
I did this job last summer and with no prior experience it took a day. There are several prior threads and I posted the MPC diagram here:
http://www.benzworld.org/forums/r-c107-sl-slc-class/2274906-diy-sub-frame-bushing-has-been.html
I don't understand why you would remove a brake line to get to the bushings. I did it with two front tires off and replaced the bushings one side at a time using a crowbar to get just enough clearance to remove and replace each bushing.
