clk 320
i am thinkin to put on 18" wheels on my CLK320, what tires size best suit if i am lowering my car at the same time? to avoid hitting the fender.......
-06' CLS500 Lorinser-08'-MC Design Whips Project SL -06' Land Rover-
If you are going 18", then it is important to know the width first. Some people go with an 8.5" with all the way around and use a 225/40/18 tire. In my case, I have a 19x8.5 up front and opted for 19x10 in the back. My car has a little bit of rubbing in the back with a much wider tire.
Mark
2007 ML 320CDI & 2009 ML 320 Blue Tec
Tire Size
The 225/45-17 tires have 24.7" in diameter, the 18" tires will 40's (lower profile) be at 25" approx., that's 3 10th of an inch bigger. Unless you are drag racing, you won't notice the difference. And on the positive side, your car will have a higher top speed.
[:D]
