Hi all,<br> Just a quick setting here; I have a C320, with 19x8.0f and 19x9.5r. The tires are 235/40/19f 34psi, 265/35/19r 32psi; Nitto 555's. It's a fairly quiet sport tire. Currrent susp. changes have been H&R springs.<br> <br> My question is to those with a similar setup. During high speed transistions on the PCH or a fast sweeping on/off ramp, the car 'pushes'. I do understand the W203 will understeer when at the limit. I'd like to know if anyone has had the same experience, and if so what did you do to minimize it? Tire pressures, camber or toe changes? Last, the next step on the suspension trail? Kleemann Shocks? Swaybar?<br> <br> <br> Many Thanks in Advance,<br> Rob C.
