2001 ML 320, 1993 LE Miata
Hello once again...
I have yet to purchase my tires and came across these sizes that are considered "plus zero". just wanted to get your opinion on these sizes, what are the pro/cons to these sizes.
Optional Tire Sizes
Plus Zero
215/75-16
225/75-16
235/70-16
235/75-16
245/70-16
285/60-16
also the last two days with the heater on or off i hear what sounds like gurgling water when at a full stop. it sounds as if its coming from the bottom of the dash closer to the passenger side. while im driving the heater makes a humming type sound. im not sure if these two things are related, any advise as always would be greatly appreciated.
02 ML320 06 ML500
The drain hole on the outside firewall is probably clogged. Remove the sound panel under the passenger side. Lay down a few towels in that area and remove the cabin air filter and the blower motor. There should be water in both those areas.
