1 - 10 of 10 Posts
S500 2000 and E320 2001 Avantgarde
i have the same fitment
can i use 255 45 18 in front and 285 40 18 at the back?
'87 300E | '04 S55 | '05 ML500
tire size calculator
Keep in mind that the first number in tire size is the width in mm. The second number is a width to height ratio. Changing the width but not the ratio will result in different circumference and therefore will offset your speedometer. There are lots of sites that will show you the difference. You should compare to the OEM tire size. Here is one... Tire size calculator
Thank you so much - this helps a lot.
2003 S55 AMG Pewter
I have stock AMG 18" wheels. Couldn't tell you the offset off-hand; without looking it up.
1 - 10 of 10 Posts
