1 - 1 of 1 Posts
ill put 19 rims on my benz with h r sport spring
rims front 19x8.5 offset.35 back 19x 9.5 offset.35
to have the best overall diamater (4matic) i would go with
front 235/35/19 back 275/30/19
Tire Size Calculator - tire & wheel plus sizing
Your Results:Start Over
Stock Tire Search Tires Tire 1 - 235/35R19 Search Tires Tire 2 - 275/30R19 Search Tires
Section Width: - -
Section Width: 9.25 in 235 mm
Section Width: 10.82 in 275 mm
Rim Diameter: - -
Rim Diameter: 19 in 482.6 mm
Rim Width Range:
Rim Width Range: 8 - 9.5 in
Rim Width Range: 9.5 - 11 in
Overall Diameter: - -
Overall Diameter: 25.47 in 646.93 mm
Overall Diameter: 25.49 in 647.44 mm
Sidewall Height: - -
Sidewall Height: 3.23 in 82.042 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: - -
Radius: 12.73 in 323.34 mm
Radius: 12.74 in 323.59 mm
Circumference: - -
Circumference: 80.01 in 2032.2 mm
Circumference: 80.07 in 2033.7 mm
Revs per Mile: -
Revs per Mile: 816.6
Revs per Mile: 816.0
Speedometer1: mph km/h
Do you think ill have rubbing problem with this?
1 - 1 of 1 Posts
