1 - 20 of 26 Posts
· Undercover Moderator
2002 SL BRABUS 5.8 Silver Arrow; 1992 SL BRABUS B11; 1996 S Class diplomat ride
front 245 40 18
rear 275 35 18
Cheers, 🍺
front 245 40 18
rear 275 35 18
Cheers, 🍺
i am looking for comfort ride as my kids will ride back seat most of the time, so i dont want it to scrape or rub
tire rack gave me 2 optional sizes
235 50 18 front
265 45 18 rear
or
225 50 18 front
255 50 18 rear
can you explain the differences with all 3 set including your size?
thanks a million!
· W163 and General M Gremlin
tire rack guy recommended :
245/45/18 front
275/40/18 rear
please let me know your thoughts, will not purchase until u reply:)
This will work too.
Slight improved ride comfort as you've notched up the tire sidewall height.
245/45/18 front
275/40/18 rear
This.....^^^... As I mention.....
Plus get an all season tires for comfort ride....
Cheers,🍺
M12 x1.5 are what I use on our monoblocks.
What oem size are you using?
00' E320, 03' E320T, 05' C230K
uh oh problem,
the oem lugnuts are too big for rim hole, what can I do? any advice? bummed out:confused:
Someone didn't do their homework.
Your 1997 S500 uses 14mm x 1.5 bolts. It's likely your Monoblock came off a W210 E55 which used 12mm x 1.5 bolts.
What are the part numbers on the back of the rims?
also i believe the wheels belong on an e55, which i did not read correctly
You have two options.
1) Sell your current rims and buy the correct ones.
2) Have the holes drilled out......I would pass on this one.
imo, I would resell these ones you picked up and seach for another set. These still fetch a shiny penny on the market.
Reactions: 260e crusier
1 - 20 of 26 Posts
