Hi All,
Please help !!!! I have a 03' 230 Kompressoer sedan with Tein-Coilover. I just got some 19' rims 235/35/19 Front and 265/30/19 rear. The tire guy suggested General UHP tires. (Wrong tires huh) I just put them this weekend and they are rubbing against my struts. I drove it a block and it cut the inside of my tires. The right side is gouged more than the left. Anybody have suggestion/what should I do? Do I need spacer? What size if I do? And will they vibrate? Thanks In Advance...
2017 GLC 300 4Matic fully loaded... but for the heated steering wheel. Stupid previous owner! 😠
Yes, the offset. Spacers should do the trick. You will have to compare the old wheels with the new ones then bolt on the old ones. One installed, measure the distance between the old wheel and wherever it was touching. Then, doing the math, you should be able to tell how much of a spacer you will need.
