1 - 9 of 9 Posts
2003 SL55 K AMG
Gang:
I've looking through the archives but I haven't found my exact problem, so sorry for the new thread.
I just purchased a 2003 SL55 with 18K miles. I have a copy of the sticker and a VIN lookup shows the
475 Tire Pressure Control
option is equipped. The problem is that I can't find it anywhere in the menu. When it didn't show up I went to Settings to see if I could see the option for setting the display between "bar" and "psi" and that option is missing as well.
So, I assume either the previous owner had the TPMS disabled (can this be done with a STAR diagnostic unit?), or all of the batteries on the tire sensors are dead and thus it isn't showing up in the display.
Sorry to bother but I wanted to make sure I wasn't missing something obvious.
-T
My educated guess is that someone had it "shut off" or disabled using a Star. If all the sensor batteries were simply dead I would think the car would let you know with an error message that the system is inop. Not 100% sure with a 2003. But on my 2007 SL the wheels I got with the car had no sensors so there was an orange light that looked like a tire tread always lit up. When I bought all brand new wheels, tires and wheel sensors, finally that orange light went away and won't come back unless a tire loses pressure. I haven't noticed whether the system shows up when scrolling through, but on my 2004 SL600 it does. On my 2008 W221 S550, you can scroll thru and set it to display all tire pressures in real time as you drive! They will start out at 34PSI and on highway, they will rise to 37-38PSI...
All four new sensors from tire rack dot com cost about $250 if I recall. Tire shops locally wanted even more money. So, some people don't want to spend the money for them. Personally, I trust sensors bought from tire rack dot com more than I would a local tire shop.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
I believe that version of TPMS uses the ESP computer to attempt to detect a low tire based on rolling resistance differences. There is no display for pressures or even a "reset" function. When ESP detects a possible low tire, it will give you a TPMS warning, but then you have to check the pressure yourself on all four tires.
2003 SL55 K AMG
Discussion Starter · #5 ·
There are numerous pages in the Owners Manual that reference a display that should show up when flipping through the various screens (in that cute little pixelated way it was back in 2003), how to reset it, as well as the ability in Settings to set the display units. I do believe in later models it just became a warning (i.e. no display)
It actually depends on the implementation of TPMS. There are actually three versions: ESP-based, low-line and high-line. The ESP-based system just uses the variations in rolling resistance/speed of each wheel to "infer" that a tire "might" be low and then you get a warning. The low-line system uses pressure sensors in each tire, but it cannot tell "which" tire is low. What you do is set all tires tot he correct pressure, then perform a "reset" which tells the system the baseline pressure. When any of the sensor's readings varies (by about 5psi) then you get a general warning. The high-line system uses ,multiple antennas to triangulate the specific position of each tire's sensors and can tell which reading comes from which tire, and display the specific pressure of each tire and tell you which one (or ones) is low.
2003 SL55 K AMG
Discussion Starter · #7 ·
Just to close out this thread I had the car serviced yesterday and the TPMS had been disabled. The guess is that the sensors were bad or out of battery and the previous owner didn't want to deal with them so had the TPMS disabled to clear the malfunction codes. I do plan to have it re-enabled in the future but after yesterday's ABC flush I'm going to wait a few months (grin)
96' S500, 09' S550, 06' SL65
Rudeny expands on my knowledge of the TPS as well. My 06' SL is the low line and does not display individual tire pressures. One would think a 200k, near 200mph car would give automatic entry to the high line club, but nope, just a general warning.
This gets complicated and is a great example of government bureaucracies at their worst. It all came about because of the exploding OE Firestone tires on the Ford Explorer (hence it's nickname of "Ford Exploder"). Firestone recalled over 6 million tired in 2000 because of this. Ironically, it was not Firestone's fault. Ford had listed a very low inflation rate for the tires to make the ride on these heavy, full-frame truck-based SUVs more compliant for the soccer mons who were the primary market. That made the tires flex more, heat up more quickly, and hot tires tend to fail. So in 2000, the NHTSA began working with congress to craft legislation requiring TPMS.
The legislation (The TREAD Act) did not get finalized until April 2005. It phased-in TPMS requiring 20% of all MY2006 vehicles to have it, 70% for MY2007, and 100% for MY2008. The law also required a dedicated TPMS system (i.e. using sensors mounted on each wheel, not an ESP-based system). The system was not required to report individual tire information to the driver; it only needed to alert the driver if any tire needs attention.
MBZ already had a software (ESP) based system available. In fact, many MBZ cars prior to MY2008 without TPMS actually have the software and it can be enabled via SDS. The problem is, once the legislation was finalized, they found it would not meet the law and by April 2005, MBZ had already started building MY2006 cars so they had to scramble. The easiest thing to do for this short notice was install sensors in the wheels and a single radio receiver module that could then communicate over the CAN bus and alert the drive on the instrument cluster. That system could actually get all the individual pressures, but it had no idea which tire was which so all you had was a generic warning, This is "low-line" TPMS. Later, when they had more time to engineer it, they added multiple antennas to triangulate wheel positions and then they had the "high-line" TPMS.
An interesting note is that many (non-MBZ) cars that have TPMS with individual pressure displays require using a special tool to program the car when tires are rotated. Basically each TPMS sensor has its onw "channel" and the car's system has to be told which tire location uses which channel. MBZ's use of multiple antennas (and they also facto in ESP information) allows for tire rotation without any programming.. Chrysler also uses this system (as it was designed by then parent-company Daimler). Many manufacturers still use system like MBZ's "low-line" where individual pressures cannot be displayed. Some are not even programmed to "understand" which is a correct pressure. instead, it's up tot he owner to technician to properly inflate all tires, then press a button (or use a special programming tool) to set the calibration.
BTW, MBZ's calibration is set from the factory but you can change it. For example, you may use the "100MPH+" inflation specs instead of the standard, which is usually a 4-5psi difference. To set your own calibration, inflate the tires, scroll to the TPMS screen on the cluster and press and hold the trip reset button until it beeps.
1 - 9 of 9 Posts
